Trans Fluid Check
1 reading
18K views 8 replies 7 participants last post by  nascarnation
#1 ·
Just bought my Cruze last Saturday and I need to know if there's a way to check the trans fluid on an auto without needing any GM specific tool? I've owned multiple S-series trucks, 1 Pontiac GTO, and 1 Buick Lesabre and I've always had a trans dipstick. The sealed trans is a whole new idea to me.
#4 · (Edited)
...per GM, they're "filled for life" of the transmission.
...of course, that answer begs the question: what's the "life" of the transmission? Exactly "...10 years and one day, or 100,001 miles, whichever occurs first..." by design or what?
#5 ·
I was hoping that wasn't the answer. Even tho the 4L60E in my GTO is running DEXRON VI I still change the fluid every 2 years and I'm pretty sure a built LS1 taxes a trans far harder than a 1.4T. I like my fluids changed regularly, ****.
#6 ·
this nothing to do with contaminents. it costs money to implement a dipstick & tube. gm would sooner sell u a rebuilt tranny than have a tranny shop change the fluid & filter. u can bet that the tranny shops will be drilling out the pan bolts.
transmission fluid does not last forever nor do clutches.
#9 ·
The first GM auto that had this system was the 4T40 which has been out a long time, back to the mid 90s IIRC. You don't need to drill anything out, just pull the pan, put in a new filter, and refill the fluid through the checking port.
My Cadillac has a 5L50 (mfg in Strasbourg, France) with the same setup. Not difficult at all to do a fluid / filter changeout.
#7 ·
I'm not sure this is an issue.
I had a '92 Saturn SC with the 4 spd. auto transaxle. At 30,000 miles, I drained the fluid and replaced it with Mobil1 ATF. At 40,000 miles I did it again. The car now has 200,000 miles on the odo (my Brother-In-Law's daily driver) with no transaxle service and the trans. is still stout enough to break the tires loose in first and second gears. This is a much older technology transmission that what is in the Cruze.
Remember, when you drain a transmission through the drain plug, you typically don't drain the torque converter. As a result of the two drain and refill operations, the Saturn has approximately 3/4 synthetic and 1/4 Dextron ATF in it.
Jim
